Its a 1001 model fat psp. I have replaced the battery, the charging cord, and ried multiple outlets. The orange light turns on when i plug it in to charge, however after several hours when i turn it on it says the battery has very little to no life left, and after 2-3 minutes of total on time it shuts off showing the battery empty screen as it does.
Your Battery may have developed dead cells and is no longer capable of charging.
Replace battery with new one
Testimonial: "I have replaced the battery, as stated in the question. That is why I am here looking for a potential solution, I am betting it has something to do with it not running while plugged in and no battery. "
SOURCE: psp 2006 battery
You don't have a problem; the seller is an idiot. Leave it plugged in for good measure, but your PSP is fine.
Many products ship with a completely discharged battery (many cellphones, for instance) and they must charge for a long time. PSPs don't; they ship with a partially charged battery.
SOURCE: psp wont charge, no usb. battery empty after last game.
believe it or not, if the psp works you can play it with out a battery using thee charger. Try that and see if it works at all. If it does then you may need to replace your battery, or leav it and let it charge for about 5-6 hours.
If it's 4 months old and it does not work at all you should still be under your manufacturer's warranty.
here is a link: https://service1.us.playstation.com/rma.htm?_flowExecutionKey=_c85468FC2-00F1-73C8-F8E5-75CD6F7D29EA_kA93A8E0B-D0A2-DB00-D631-BB67FD1DF0A2
SOURCE: My psp wont start! When i Charge it will just show
You may need to send this in for repair. If you are out of warranty, you should try a place called www.videogame911.com. They are really fast and can repair any problem.
SOURCE: psp trouble
it might be a bad battery. try useing i diffrent one. like from a friend or something.
SOURCE: I have a PSP that I charged overnight and a orange
Remove the battery.
Plug the PSP charger into the PSP.
Turn it on.
The PSP works with no battery inside.
If you're not getting a green light at all, your PSP has some sort of damaged as it should work while plugged in with no battery inside.
It also does not turn on while plugged in, with or without the battery in. I know it is supposed to, but it does not.
