What you will need to do to correct this problem is delete the series recording. in your list (push list button) highlight the program you wish to delete, push select go to "rec. series" press select. and delete ALL push select... get "ok" message, select again. and reset receiver on front panel of receiver there is a door you can open, hit the red reset button and then setup your series record again by going into the guide and pressing record twice. this will fix the problem by deleting ALL of the series record and resetting, and resetting up series record
just talked to directv. they have a system wide problem that's causing the recording problem. don't know when the fix will be in.
Do you have 70 hours worth of shows recorded? Perhaps the hard drive is full.
