I'm not sure what model it is, but my best guess is Kwikset ''660'' Deadbolt that can only be locked from one side. I opened the deadbolt with the key from the outside of my door, but now my key is stuck in the deadbolt. I have already taken the deadbolt off the door and the key has still not come out, so is there some way to get the key out?
Spray a little bit of oil where you insert the key turn it a couple of time to make sure it is lubricated then turn to correct location to pull out key hold cylinder in with finger key should pull out
From a pro-locksmith: Tim Carter is probably correct. Graphite or tephlon spray is best. WD-40 will work in a pinch. Stay away from heavy motor oils. Although it may solve your problem temporarily, it will gum up your lock and lead to other issues. Check out http://localinventor.com
