My iron fell onto a table and the steam gauge broke. The iron does not produce steam. How can I fix the steam gauge?
Http://www.fixitclub.com/Parts_Components/Appliance_Controls.shtml
click the link
Maintenance and repair tools you'll need to fix an electric iron include these:
you will need a speacial tool screw driver
also called as g5 screw driver to open it.available at local repair store.
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
There is a problem in the Steam Gauge... means its not ficed untill you change tham..
better you take it to a service center to change that gauge..
Good Luck!!
Thanks for using FixYa...
You must be kidding. I certainly do not need to pay 9.99 to have someone tell me the steam control is broken. I know that. My question is how to fix it myself.
What is a coil? How do I find it? How do I know if it is working properly?
The screw holding the plate is not a conventional screw. None of my screw drivers fit. What type of tool do I need to remove these screws?
