Question about Pyramid PS14KX 270-Watt Power Supply
Pyramid Power Supply manual
Is there a PS 14KX manual available for download? I lost mine and need if for a problem I'm having. Raymond L. Beck
  • 748 Answers
I found one at www.retrevo.com
Posted on Mar 25, 2009
  • netguru999 Aug 27, 2011
    nice link to a sale site, no schematics
SOURCE:
Where can I get a free download of an owner's manual?
You can try contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
Dec 31, 2015 | Pyramid Ps-52kx - 52 Amp 12-15v Ac To Dc...
I've got a new pyramid ps52kx, right out of the box. It shows 7.8 volts on the meter and the potentiometer will not adjust up or down, no control what so ever.. I did put an old used radio on it and no...
Have you set it up properly ? Consult instruction book. If you are certain it is defective, get a refund under the warranty (if it's new it should still be under guarantee)
18.January.2015.
Jan 18, 2015 | Pyramid PS52KX Pyr 46 amp power supply
Power supply smoked capacitor
Recommend contacting a local car audio professional or Pyramid customer support directly here:
Mar 30, 2014 | Pyramid Ps-52kx - 52 Amp 12-15v Ac To Dc...
I have an ps-21kx unit that puts out 26 vdc and not 13.8 vdc
Scotty; I need more power!
Jan 30, 2014 | Pyramid Ps-21kx 20 Amp 13.8v Power Supply...
Hi,We have a Pyramid Gold Series PS-26k that won't
try changing the battery out
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 21, 2009 | Computers & Internet
Re: Pyramid PS-36kx power supply buzzer sounded,red light came on
Hi! I saw your question, and maybe this will help. I also have a Texas Star 100w amp, and this same power supply. Even though the nominal draw for your equipment is way below the rated amp flow of the power supply, when you key up, and the output on the amp is at max, you are drawing the limit of your power supply! Try running this setup at a lower linear output. You don't need the full 100 watts to get out! 60-80 watts is aplenty! You should start at a low output, and slowly increase the output(while keyed up), untill the power supply starts to complain.(buzzer/light). This is what your limit will be. The only other cure, is a MUCH bigger power supply. Unfortunately, I cannot afford a 60-90 amp supply, so this is what I am forced to do to use the one we have. Also,keep your cb's output very low when using the linear amp. These amps are supposed to get a low signal from your radio, or the linear amp is overdriven. (noisy and unstable. Hope this helps you! 73's to you! jimsjinx
Apr 30, 2009 | Pyramid (PS36KX) 600-Watt Power Supply
Connecting a Cobra 29LTD to a Pyramid PS-3KX 13.8VDC Power Supply
The wires should just attach to the red and black terminals on the radio, strip some wire unscrew the terminals a little wrap behind, and tighten again. Good luck! Or buy some banana plugs and they will plug right in the front
Dec 18, 2008 | Cobra 29 LTD CB Radio
Pyramid ps-21k power supply
you need to get the voltage regulator circuit checked in your ps-21k
Jun 13, 2008 | Pyramid 10 AMP 13.8V POWER SUPPLY Car...
Pyramid PS14KX 270-Watt Power Supply Logo
1,565 people viewed this question
Top Pyramid Computers & Internet Experts
k24674
Tom Chichester
Are you a Pyramid Computer and Internet Expert? Answer questions, earn points and help others
