Pyramid Ps-14kx 12 Amp 13.8v Power Supply Ac To Dc Logo
Kimberly Posted on Jun 27, 2013
Pyramid PS-14KX problem
I was using my pyramid for 10 minutes yesterday when it went into protection mode. Now when I turn it on and the green normal lights up, but the minute I plug something in and draw current, it will go into protection mode again. I put my hand on the two 3055's and they are not hot. I took the cover off and there is no burning or smell. the minute i unplug from the unit it will go back to normal, then when I turn the unit off, the green normal light stays on for 3 to 4 seconds and then fades. Any suggestions? I also tested with my amp meter on several areas and it seems to be getting power through them where I tested.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jul 09, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1635
Points
Not enoghf power in
Hooking up red black wires
I prefer green and white, but that's just me.
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
3helpful
Pyramid arctic 4ch amp pb1617x goes right to protect mode when turned on wires are good fuses are good to. how do i fix it
pull out 1 rca jack at a time and try it..usually speaker wires touching...or blown speaker
1helpful
Hi,We have a Pyramid Gold Series PS-26k that won't
try changing the battery out
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
1helpful
Green and red light are on my pyramid amp and its not working
It could be even simpler than that, yes an improper impedance rating on an amp will cause it to overheat, but should function temporarily until it reaches peak temp. If the outputs were blown the protect light should not light up being that they would need to work to cause the protect light to come on. I would double check all of your connections, one small little crossed wire would cause an amp to immediately go into a protect mode.
Pyramid ps-36kx
Generally, the fuse only blows when the rectifiers fail. In other Pyramid supplies, they use a square, 4 terminal bridge rectifier. They probably use the same thing in your supply.
Let me know if you have any other questions.
Pyramid ps-21k power supply
you need to get the voltage regulator circuit checked in your ps-21k
2answers
PS36K power supply overload problem
Most of Pyramid's supplies are based on the LM723 voltage regulator. The DATASHEET should tell you most of what you'll need to know to repair it. THIS is the schematic diagram.
If the output voltage drives the voltmeter to the end of the scale, it likely has one or more shorted power transistors.
Top Pyramid Car Audio & Video Experts
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
xxxxxx xxx
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
