I have got TD-W8951ND model router, when i connect it to phone line through splitter ADSL LED light only blinks few times(max 4 times)and stops blinking.when i connect my friend's router to my phone line it works.so there is problem with my router .Is there any solution to it ????????
SOURCE: wireless router not connecting
Be sure that your Modem plugs into the WAN port on the router.
1. Unplug your cable/dsl modem power
2. Unplug your Router power
3. Plug in your modem power ... wait for it to come completely up.
4. Plug in your WRT54G Router and wait for it to come up.
Press the reset
button on the back of the router for 45 seconds while it is powered on. This will do a factory reset. Wait for it to come up. Then unplug it. Wait 30 seconds and plug it back in. Let it come all the way up.
Plug a PC into one of the switch ports on the router.
Now do an ipconfig /release and ipconfig /refresh in the command prompt of your PC to get an IP address from your Router.
Now you should be able to ping 192.168.0.1 and you should be able to get into the the configuration utility by putting http://192.168.0.1 in a browser. The username should be blank and the password will most likely be admin (all lower case).
Be sure to lock down your wireless SSID
so neighbors and people passing by are unable to connect to your access
point and do bad things on your network.
SOURCE: USB and ADSL light blink, no logon
I trashed the Zoom modem and get an Actiontec. This is the second Zoom modem that I have had that bit the dust.
SOURCE: 6381-A3-302,6211-I1-300 Paradyne ADSL 2+/Bridge Router
i have paradyne paradyne 6381 a3 302 lost the driver cd. My new windows xp don't pick it automaticly. plz give me a slution.
SOURCE: adsl led is not glowing 802C D-link
when the adsl is not blinking that means your phone line is having problem plz ask your phone line provider to check the line.
