Platter doesn't always spin without a slight nudge. Also doesnt stop dead on start/stop. Does this require a new motor
SOURCE: technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
SOURCE: The platter on my Technics SL 1200MK2 stopped spinning
If you remove the rubber pad from the top of the platter then you should be able to lift the platter off the servo drives' center shaft,
from memory the unit is not attached just held on by gravity,if the servo magnet is gone the take it in for a service and pay the man for his time,
My first problem on my 1200s was a pitch control issue and easy to fix,with a little cash,never use second hand parts unless you know what you are doing because when they fail on you while playing to a packed dance floor then youll get more of a supprise than you barginned for,
Misterdj
Never, to my knowledge, been opened either. Certainly not in the 10 years I've had them, although they were second hand when I got them
