Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Leaves white marks on coloured clothes
My Whirlpool Ulitmate Care II top loader leaves white marks on coloured wash even after selecting extra rinse, (it's particularly bad when doing black or dark wash). I use only a liquid detergent with no additional softner or bleach. This machine is about 5 years old and had been working fine, until this problem started about 6 months ago.
  • 4 more comments
  • ronnieconlon Mar 25, 2009
    On mains water supply. I do not use water softner, (water in this area does tend to be a bit `hard').
  • obbo Apr 24, 2009
    I am having the same problem. Small bleached like circles, size of drum circles, on colored clothing.
  • st_donnas May 03, 2009
    Whirlpool Ultimate II is leaving a lot of fluff and its spoiling all my dark clothes especially. I really need to resolve this problem quickly. Any tips on how to get the lint to clean out?
  • steve
    steve May 11, 2010
    Minerals in hard water will accumulate over time.
    Pour 2 cups white vinegar in the washer and run a wash cycle with no laundry. It should remove most of the buildup.
    Use hot or warm water when possible on dark clothing.
  • steve
    steve May 11, 2010
    Are you on city water?
    Do you use a water softener?
  • wrgoss1112
    wrgoss1112 Feb 05, 2013
    I also have a whirlpool about 8 moths old and it does the same thing ,white streaks on dark clothing,but I can say the solution by Steve White does not work,tried it
  • 144 Answers
I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
Cheers
Posted on Mar 25, 2009
    New Friend:
I have a whirlpool about 8 moths old and now it is doing the same thing i
Posted on Feb 05, 2013
  • 1 more comment
  • wrgoss1112
    I have a whirlpool about 8 moths old and now it is doing the same thing this solution does not work
  • V Westell
    V Westell Mar 10, 2014
    Mine are about 6 months old and didn't do it the first month or two but is now. I use liquid detergent HE did you find a different resolution? My 2 girlfriends have the same set about 4-5 years older though and they said they have never had this problem. It is driving me crazy!
  • Lisa Harrison
    Lisa Harrison Mar 16, 2014
    having same problem, have tried cleaning the machine with AFFRESH several times does not help
SOURCE:
Ken more washer leaves dirty marks on clothes
Pull the agitator out and clean the inside of it and the area of the tub that it covers. A buildup of crud won't be removed by simply washing out the machine. Rinsing out a frying pan will get a lot of the dirt out but, it must be properly washed to get it all.
Jan 20, 2013 | Washing Machines
Ultimate Care II top loader washing - rinse issues
New concentrated powdered detergent takes very warm water to break it down. As for most dark clothes use cold water. I have one of these top loaders and for my cold wash colored clothes I use a liquid detergent and have no problem.
May 06, 2010 | Whirlpool LSQ8000 Top Load Washer
Washing comes out with marks
Yank that dispenser off the top of the agitator and wash some clothes without it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The washing detergent doesn't wash out of the clothes it leaves marks on the fabric. what is wrong?
Too many clothes in the load , reduce by 25%
Switch to an old fashioned soap powder that has more agents in it to help it dissolve
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine starts by itself
going through to the next wash not na normal function, perhaps the machine is advancing to an extra rinse cycle?? this EXTRA RINSE will start after the normal wash is complete, i would check your dial settings perhaps some one has mistaknely switched extra rinse "ON". if htis os not tyhe case the n i would jave to blame a faulty timer mechanism and you would need to replace the timer
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer leaves water
Water pump must not be running. Check if the belt is not broken or came off or the dial switch is bad or the clutch is not engaging.
Good luck
Dec 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
White spots on color clothes
try using calgon tablets, they flush out washing machine for limescale, perhaps it will work for you
Jul 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II GSQ9669LGO
Sounds like you may need to replace the timmer
Jun 06, 2006 | Whirlpool Ultimate Care II GSQ9669L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
1,396 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
