Question about E-Machines T6520 PC Desktop
Screen saver freeze
When my screen goes to screen saver mode, i often return to it in a frozen state. there is nothing i can do except turn the computer off since even my ctrl/alt/del will not take it out of that mode. why is this happening? it is not my screen either, as i just got a new one.
  • unterkofler Mar 26, 2009
    i just turned off the animation on the screen saver and we will see what happens. thanks.
  • Anonymous May 11, 2010
    which screen saver do you use?
  • 38 Answers
Its probably your graphics card or driver. Try changing your screensaver to one without animations, if that fixes it you need to look into your graphics processing.
Posted on Mar 25, 2009
SOURCE:
My LG Transpyre that powers down immediately after i turn it on even though it has a full charge
check your power saving settings,start the device in safe mode, Safe Mode puts your phone in a diagnostic state (returned to default settings) so you can determine if a third-party app is causing your device to freeze/reset/run slow.check links below for more info.
press the helpful button and follow me on fixya for more tips and info
Power Saver On Off LG Transpyre
Restart the Device in Safe Mode LG Transpyre
Feb 03, 2016 | LG Computers & Internet
Why no video
a HP monitor. as old as 2006... (o0ps)
read the manual yet? on "power saver modes" turn off them?
i bet you dont know spec, on caps. it's not published by HP ever.
most are +80% - 20% for filters. (ever seen that?)
so a 100uf can read 180uF, or 80uf and is IN SPEC.
but no caps stated, by you, lots there are...
my guess you are
looking for the caps used in china long ago that all failed, every one.
first off you never fully stated whats wrong, in DETAILS.
first have good running pc , with live VGA output (using VGA are you)>? unstated...
the MON, will now live sync, now , Horz and vert, on both pins
the OSD screen now works, if not the monitor is bad.?
or see No/syn, no sig, out of range or no input errors.
Monitor Going to Sleep
see page 34? in your manual yet?
and page 31, turn of power saver ?
if OSD is dead, say so first.
OSD can be locked. push mon menu button for 10sec, now unlocked
then go to OSD screen
http://h10032.www1.hp.com/ctg/Manual/c00834092
Power-Saver Feature
When the monitor is in normal operating mode, the Power li
ght is aqua-white or green (depending on model) and the
monitor uses the normal watts of power. For power us
age, refer to "Technical Specifications" (Appendix B).
The monitor also supports a power-saver mode that is
controlled by the computer. When the monitor is in the
reduced-power state, the monitor screen is
blank, the backlight is off, and the
Power light is amber. The monitor uses
minimum power. When the monitor is "awakened," a brief
warm-up period occurs before the monitor returns to
normal operating mode. The energy-saving reduced power stat
e activates if the monitor does not detect either the
horizontal sync signal or the vertical sync signal. The powe
r-saver feature must be activated on your computer for this
feature to work, << read that carefully?
turn this off ? first?
osd-vboix4tqi2kfzapulla5cn4x-5-0.jpg the early models of the monitor
had CCFL back lamps, and the 2 inverters are on the main power board. left side here
http://i.ebayimg.com/images/g/2-wAAOSwzSRZxoWH/s-l1600.jpg
Sep 28, 2017 | HP Compaq WF1907 19" LCD Monitor
My Sony Vaio VGC LA2 shows green lines at startup and after windows processing screen it goes blank. The problem started when it used to hang-up whilst the screen saver came on and the system freezes...
have you tried booting in safe mode?
as the system is booting repeatedly press F8 until a menu appears where you use the aarow keys to select safe mode by pressing enter.
Jan 24, 2011 | Sony Computers & Internet
Monitor goes to sleep
go to control panel, display properties, screen saver, turn off,
than go to power options, turn off the "turn off display" option.
Jun 06, 2009 | HP Computers & Internet
Dell Inspiron 1100 screen goes into power saver mode after 45 sec
it sounds like your most likely having trouble with the hibernate feature try this
start>>control panel>>power options>> click on the hibernate tab
un check enable hibernate mode
this should fix your issue
Apr 10, 2009 | Dell Computers & Internet
Periodically the page on screen goes blank
Windows inactivity for screen saver is set. If you want it to deactivate.
On Windows desktop screen, right click mouse a pop up box will show. Select "properties" or "personalize", go to screen saver. Uncheck the box with " on resume, display log on screen". And on screen saver box select NONE this will unhighlighted the inactivity time and the logon screen. Hit apply and then ok button.
This will deactivate the screen saver.
Mar 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
Full screen probs with netflix
This has nothing to do with Netflix, you would get the same result with any DVD regardless of its origin. Chances are that is the laptop trying to revert to a screen saver or power save mode during the movie.
Check your laptop's power and screen saver settings. If you are experiencing the problem every 3 minutes or so, your screen saver is most likely scheduled to go on after 3 minutes of inactivity. The same goes for your monitor-- it may try to dim or turn off after a certain amount of time.
To change these settings to a longer delay, go to your desktop and right click. Select "Properties". Choose the "screen saver" tab, and change the "wait:" field to a higher number. Or, just turn the screen saver off by selecting "(none)" under the screen saver dropbox. You may also click "Power" and change the time for "turn off monitor" to "never", or a longer amount of time.
Jan 04, 2009 | Toshiba Satellite M115-S3094 Notebook
Dell XPS420 Freezes after being in sleep mode
Is there a reason why you cant turn off sleep mode and just let the screen saver kick in? You can do this by right clicking on your desktop and goto properties. Then ScreenSaver, then click on power.
Change these values to never and then go back and set your screen saver...
Hope this Helps...
Joe
DataMiner
Sep 14, 2008 | Dell Dimension XPS PC Desktop
ENERGY SAver is stuck on
I know it's an older post, but you still may be waiting an answer:
What is probably happening is Your power board is failing to maintain power enough to run the bulbs and the rest.
That is why it takes long to start up and why it goes into sleep mode.
Does the power button stay lit (getting signal) or turn to amber (sleep mode) or does it flash.
powerseller
bammbammfran
Sep 04, 2008 | Proview PL926WBi 19" LCD Monitor
Screen going blank and laptop freezes.
Go into the diplay properties, under the screen saver tab there is a button marked power, open this. Under one of the tabs there is a section that reads, when I close the lid, under this section set it as never.
Jul 10, 2008 | Dell Inspiron 1000 Notebook
E-Machines T6520 PC Desktop Logo
69 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
