Hello
I bought a 9 piece assorted templet kit for my porter router 1001. Everytime I use any of the templets the lock nut comes loose. I tighten it much as it will tighten...but it won't stay.
Obviously, this creates a dangerous situation. I'm now a little hesitant to use the router but I have a work project that needs to be done and I need this router to be safe and effective.I don't want flying metal pieces hitting me or anyone else...any input is greatly appreciated.
please advise.
karl
This is a common issue with these kits. Some guys put a little shred of paper in the threads as they screw it together.
Try to reach inside the base and grap the knurled ring with a pair of channel locks and you should be able to get sufficient grip on it to tighten it enough to keep it from spinning loose.
If it still works loose, you could put a little rubber cement or Spray adhesive on just a bit of the threads, let it dry, and then screw it together. It will be harder to undo, but should keep it from vibrating off.
Finally, if you have a lot of work to do with the template guides, try to make a point to check it occasionally. In this way, you are more likely to catch it before it comes loose enough to do any damage. I don't believe it could spin off all the way, but it can loosen to the extent that your work is damaged.
I hope this helps in some respect.
Best regards.
