The following instructions shuld have you in hot coffee in the am.
S E T T I N G T H E C L O C K A N D D E L A Y B R E W T I M E
On programmable models CGX20/CGX23 & CGTX84/CGTX85 only
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to
indicate that the time has not been set yet.
2. Press and hold the HOUR and MINUTE buttons until you
reach the current time. The PM indicator will light on the left
of the display.
The clock is now set!
NOTE: Pressing any button before setting the clock will cause
the clock to start keeping time from 12:00 a.m. You must set
the clock if you want to use the Delay Brew feature.
To Set the Delay Brew Time:
After setting the clock, simply press and hold the SET DELAY
button (Figure 1), and set the brew time by pressing the HOUR
and MINUTE buttons. The PM indicator will light up on the
clock display.
The Delay Brew Time is now set!
NOTE: To activate the DELAY BREW cycle, see the “Brewing Coffee Later” section.
To check the programmed time, push the SET DELAY button. The display will show the time you have
programmed the coffee to brew.
http://www.mrcoffee.com/Manuals/MANUALS/CGX20_43_62164399.PDF
Thanks. It works!! Good job!! Pat
