When power button is depress laptop does not come on. Battery pack fully charge. Can you please help?
SOURCE: Toshiba M35X-S109 Doesnt Start
you may have a faulty motherboard connection, but try connecting the power adapter in without the battery and see if it runs, then replace the battery back in the compartment.
SOURCE: Satellite A100-166 PSAA9E does not charge the battery
Your power controll circuit on the main board is bad, you might need to change that or the entire board itself.. If you can get a technician just to repair the power controll circuit you should be fine. most ppl dont do that cause its difficult. Normally your entire main board is replaced. To fix that i will need to see the board but thats difficult since i am sure you dont live anywhere close to trinidad but i am sure someone close to you will be able to repair it, or your can download your service manual for your laptop and attempt to repair it your self.
SOURCE: Cooked motherboard, blown fuse, blown power pack.......
It's time to take the laptop to a qualified technician; if there is a fuse, then it is _not_ an "end-user" task to disassemble the laptop, to change the fuse. If it is _not_ a fuse, then the technician needs to do more trouble-shooting than what you, as a "user", currently know how to do.
