We have the Norstar m7310 system and I would like to set additional phones to ring, in addition to the receptionist phones. We need to hear the phones ring in all areas of our office and not just in the front office.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
if the programming doesn't look like 1 described call me @1.410.984.4840
If your Telecom equipment provider has set up "user" programming on the system, you can enter the administrative programming mode from any phone by dialing **ADMIN (Star-Star-2-3-6-4-6). The phone display will then prompt you for a password. The default is ADMIN.
You will need the appropriate NORSTAR MICS or CICS manual to accomplish this taks.
The 4 upper right keys underneath the display change meaning when you are in programming. The back of the programming manual has a perforated overlay to place over the keys when programming.
Upper Left = HEADING
Upper Right = SHOW
2nd Key Left = BACK
2nd Key Right = NEXT
The NEXT key scrolls from menu to menu - the SHOW button displays a particular menu
As you move from menu to menu, the 3 keys on the display allow you to change the data.
After changing the data, you must press NEXT to save it.
Press the RLS key to exit.
Thank you very much it worked to a tee!
The phone is put on Nights at the end of the day and the phone in an employee's office will not ring, she is farthest away from the reception area
