I have a Coleman Powermate Model Number BV6548049 6 5 HP two stage 80 Gal Vertical Air compressor. It has developed a leak where the small aluminum supply line connects to the Pressure Switch. The leak seems to be occurring in the flange that connects the tube to the pressure switch. I have replace the pressure switch and re-done the pressure connection where the tube enters the pressure switch. It still leaks in the same fashion as the old switch. Is there an adjustment I have neglected to set???
Usually, a leak at the pressure switch unloader valve is caused by the checkvalve in the tank. The unloader valve at the pressure switch bleeds out the air from discharge tube after compressor reaches set pressure. This only takes a few seconds. If air continues to leak then air is leaking back into the discharge tube past the tank checkvalve. Follow the air discharge line from the compressor to the brass valve at the tank. The brass valve is the checkvalve that holds the pressure in the tank. There are usually two connections at this valve. One is the unloader tube to the pressure switch. Simple test for leaking checkvalve, with pressure in tank unplug or switch off the compressor and remove the small unloader line at the checkvalve(brass valve) and look/listen for leak. If leaking, remove the checkvalve and examine seat/check for debris keeping the valve slightly open. If it cannot be cleaned, order generic replacement from www.grainger.com. It will cost less than the factory checkvalve. Just pay attention to the thread sizes for easy fit. Good Luck on your repair and email if you have questions.
Thank you, I appreciate the quick response. I will attempt what you have suggested and let you know how it turns out.
