Follow the steps below to switch your TV to game mode without using the remote:
1. Connect the game system to the TV using the AUDIO/VIDEO inputs on the FRONT of the TV.
2. Switch the game system on.
3. Press the "MENU" button on the front of the TV
4. Use the "CH" UP/DOWN buttons on the TV to highlight the "PICTURE" option. This is the first option so should already be highlighted.
5. Press the "VOL UP" button to select this option
6. Use the "CH" UP/DOWN buttons on the TV to highlight the "GAME MODE" option. This is the first option so should already be highlighted.
7. Press the "VOL UP" button to change the GAME MODE setting to "ON"
The TV should automatically switch to GAME MODE if you are using the inputs on the front of the TV.
8. Press "MENU" to exit and play your games.
Hope this helps. Please post back if you need further assistance.
Sorry Sarge...this problem is not that simple...and for some reason these Sylvania tv's won't allow you to access game mode that easy. I think the best idea (assuming the universal remote doesn't work out)...just buy another ORIGIANL remote from the manufacturer! Hooowah!
is there a TV/Video or menu button on the front of the tv? if so try the tv/video button, that should scroll through the the components you have on your tv. dvd, game cable etc. If no tv/video, hit the menu button and then use either channel up/down or volume up/down to scroll through your component options.
Go to Radio Shack and get an universal remote control, i have a Phillips Universal for mine. it has a tv/vcr button that also is an "input" button to switch channels to do this.
go up to your TV and go into the menu. Go to the channel selection and run the auto select for channels. This will take some time but the TV will end off the first channel found, the only thing is you cannot get back into video mode without the remote
I got mine off of game mode by using a universal remote. I had to type in a channel, (03) and it got it out of game mode, but I now have the problem of not being able to get it back into game mode so that I can use my DVD player. Good luck
not familiar with this model
but ill try
try in the menu puting it on game mode
then look for external input mode in the menu and turn it too
dont work
fix ur remote or bye a new one (be sure that the new remote will activate the game option)
good luck
windman
