I can't get the interent explorer to come on and when it does it goes off right away or it gives a error message. Can you help on that.
Sir/ Madam-
Normally this happens when customer Ie files are corrupted or Temp files are causing the problem..
Go to Control Panel\Network and Internet\internet option
Please try below steps it should fix the issue--:
Clear cached data in Internet Explorer 7
loadTOCNode(2, 'moreinformation');
To determine whether a performance issue or an error message is caused by corruption in the temporary Internet files or in other cached information that is used by Internet Explorer 7, you must clear cached data. To do this, follow these steps:
Reset security settings for Internet Explorer 7
If you configure security settings to be too restrictive, you may prevent Internet Explorer 7 from displaying certain Web sites. To determine whether an issue is caused by overly restrictive security settings, revert to default security settings. To do this, follow these steps:
Reset Internet Explorer 7 settings
To determine whether a performance issue or an error message is caused by configuration settings, reset Internet Explorer 7 to its default configuration. This was its state when Windows Vista was originally installed. To do this, follow these steps:
You do not say which version of Windows you are using or the version of Internet Explorer so here is a general idea to fix.
If you are running XP or Vista download the new version IE8 and install it. Here is the link:
http://www.microsoft.com/windows/internet-explorer/default.aspx
Sir/ Madam-
Which version of Internet Explorer you have ?
