Televison & Video Logo
Brian daly Posted on Jun 26, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a no signal prompt on my jvc flat screen, the Verizon fils box is working, how do I fix it?
Steve
Level 3:
  • Master 3,290 Answers
  • Posted on Jun 26, 2013
Steve
Master
Level 3:
Answers
3290
Questions
Helped
1128183
Points
12184
Make sure you have selected the correct INPUT. Many TVs have several from which to choose. Locate the INPUT or A/V button on the TV or remote. Press it once and wait up to 3 seconds to see if the picture appears. Repeat to cycle slowly through all inputs until picture appears. Some TV / remotes have buttons labeled AV1, AV2, AV3, etc. or similar do go directly to the specific input as opposed to cycling as above. Press each - one at a time - and wait up to 3 seconds for picture to appear.
If unable to display a picture, check A/V cables at cable box and TV. Note which input is being used on the TV for the cable box. Then select the same AV input on the remote that is being used on the cable box.
If still no picture, contact cable company / Verizon for service.
2 Related Answers
Anonymous
  • 320 Answers
  • Posted on Oct 18, 2008
SOURCE: Sony HDTV flat - no picture with HDMI cable and Verizon FIOS box
Probably a handshake problem with the cable box. It is common for cable boxes to have HDMI handshake problems. Hook the box up using the component cables and you should be fine
Anonymous
  • Posted on Jan 15, 2011
SOURCE: No picture on Westinghouse flat screen tv
westing house flat screen tv hd...has sound no picture
JVC LT-42E910 LED flat screen TV, backlight comes on, menu box is displayed but after about 5 seconds backlight goes out. Picture and sound still working but no backlight. How can I troubleshoot?
jvc tv backlight Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on jvc tv backlight related issues. ...JVC LT-40SX6AT flat screen. Was watching TV ... ...jvc logo, has sound but nopicture Backlight is defective. I suggest ... Question about LT-42E910 42" LCD TV.
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD ... LNT KDL Sanyo ln FLATSCREEN TV REPAIR FLAT SCREEN FIX - Hear Clicking .... i have a JVC LT42E910 WITH a cracked screen. there are all these color .... Vizio LCD Powers on with backlight, Wont power off, No video ...
Wont connect to verizon dvr box, its connected to the video out cable and the fios tv cable.
Make sure that the dvr is not outputting a HD signal to your set - if it is, your set will not work unless you change the signal to 480 from the HD setting.
NO CHANNELS
What specific model of JVC multi-system TV do you have? What is the signal source?
The majority of the JVC multi-system TVs that I've researched only have analog tuners (NTSC, PAL). The AV-29LX is an example of the older JVC TVs. Since most over-the-air signals are digital, you will need a digital-to-analog OTA signal converter to watch any signal from an aerial TV. If you have a cable system that has upgraded to digital cable, you will need a cable box.
Converter boxes are harder to find but there are a few remaining. Here's one for the US: http://www.amazon.com/Magnavox-DTV-Digital-Analog-Converter/dp/B0013ZKZGU .
I wish that I had better news for you.
(A few low-power stations still broadcast in the analog format. However, you have to be really close to the station or have an outdoor antenna to have a chance at receiving the signal.)
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
5answers
HDMI crap out
I got the solution. Contact Customer Service, ask for LEVEL II Tech, and ask them for the old firmware. It will take a lot of pressuring, but they will send it to you and then it will work fine!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
