F20 code occurs during wash process. I have removed inlet lines and checked screens, I have removed the drain plug and fished our nursing pads and baby socks. Recently I have discovered bleach and soapis not dispensing correctly. I am wondering if I should replace the inlet valves or flow meter?
SOURCE: f20 error code???
Ok, I found 2 solutions for this problem, I tried the first one, and it really seemed to work, but I think I will do the second one too. First, if you have metal flood safe hoses, you need to look for debris blocking the filter at both ends. I kept checking the screens at the washer end and not seeing anything, but there was debris located at the water supply end, stuck in the flood safe device that is in the metal hose. Also, Flood safe hoses say to turn the water on to full pressure, but sometimes that can activate the flood safe device, so only turn your water supply on half way. Make sure that the hoses are on right as well, the flood safe device needs to be at the end with the water supply, not the washer end. You will be able to see the device (it looks like a little sieve) inside the hose.
Another cause of this problem can be the filter IN your washer, it is located in the front just under the front bottom removable panel. If you have a pet in the house, definitely check this out, a lot of hair gets stuck in that. Just unscrew the front bottom panel, and then it is right in the middle at the bottom, a cone shaped filter. Get a towel, because there will be water in there, too. Check out this link with pictures: http://enginerdandwife.com/2007/03/kenmore-elite-h3-washer-error-code-hf.html
SOURCE: HE3t f20 error
We had the same problem with a new machine. We washed one load successfully and the second time we got the F20 code. Sears came out and determined it was a bad valve. They had to then schedule another service call to fix it.
The new part was shipped to our house. The repairman showed me the old valve with some black debris on it, saying that our lines were dirty and that contributed to the problem, but its hard to understand how one use of the machine would clog a good valve. Anyway, with the new valve the machine works fine.
SOURCE: F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
