134 and the amount depends on how much is left in the system. If yu have a small leak a 16 oz can may be all you need. If it's all gone then you'll have to remove the air that has entered the system with a vacuum pump for an hour or more before adding freon. In that case the amount is on a label under the hood. You'll need a hose with a gauge on it to add freon. They can be purchased with or without a can of freon attached. You connect the hose to the LOW pressure side of the system and stop adding freon when the proper pressure is obtained on the gauge.
SOURCE: CD Changer doesn't work after changing battery on Jeep Liberty 20
The CD changer probably failed to establish it's link to the head unit when you put the new battery in.
Since you've already tried the clear button, I'd suggest unplugging the IP-BUS cable (black cable) from the back of the changer, wait a minute (literally, 60 seconds) and plug it back in.
Do not add over 2 lbs. I just had mine recharged in Va. Beach., type is under the hood.,if you can't find it I can get my receipt out and give you that.,do not overload on the AC recharge though,it could and can freeze up and not work at all like mine once did.,before.
