SOURCE: Need to replace drain hose
there is a kit available to replace just the part from the back of the machine.normally the drain hose comes with the wiring loom big job.not sure what country you are in.kit is available in australia.
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
SOURCE: Fisher and Paykel GW612 - Lights showing
Hi just read your posting.The fault on your machine is called Single Rotor Position Sensor Error.The rotor sensor is attached to your motor which is located underneath the machine.Now the Error Code will come up on your machine because 1--The wiring to the Rotor Sensor is faulty. 2-- The rotor sensor itself is faulty or 3--- The motor controller, 'which is located under the top panel is faulty.Unfortunately to test the rotor sensor you need an RPS tester .This device will also check the wiring to the rotor sensor.If you have an electrical test meter I can guide you throe the testing of the wires to the rotor sensor but without the RPS tester you cant accurately test the rotor sensor.Some service techs I know just change the rotor sensor to see if that rectifies the fault but in your case you dont have a rotor sensor so even if you do purchase one and change it, the fault could be your Motor Controller.My best advice to you would be to borrow an electrical test meter if you do not have one and reply back and I can help you eliminate the Wiring as the cause of the fault,and then contact a service tech to find out if the fault is with the Rotor Sensor or the Motor Controller.But if the fault is with the wiring then I can guide you throe step by step to repair it.I hope this helps and please reply on how you got on or if you need further assistance.Good luck.
SOURCE: water will not drain out
Hi just read your posting.1st you need to drain some of the water by hand using a small bucket or pot ,enough so you can lean the machine back to look under the machine.If you have the old style of pump you will see a red or black fan under the machine front right.If you have this pump turn the fan a few times to loosen it.The fan should turn freely.Then put it back on its feet and select a spin cycle and push start.It should start to drain and then spin.Please reply on how you got on or if you have the new type of pump which has no fan.Looking forward to your reply.
