I have a Sub Zero 532 side by side refrigerator. It has the alluminum handles that go down the whole length.
I want to remove the white panels that it currently has and have stainless ones made. I need instructions on how to remove the panels.
I know I need to take the handles off but want directions on how to do that without breaking anything!
Thanks for any info.
Hi, there is a metal strip that runs down the middle of each door the entire lenth. It is held on with two magnets. Once you pull that strip of metal off, you will see five screws that hold the door handle on. Remove thos five screws and the entire handle comes free. Slide out the panel and replace the handle, screws and metal strip ion reverse order. Take your time removing the magnetic metal strip as it is a very soft metal and could possibly bend or kink up on you.
Hope this helps. I'm having some trouble locating any company that makes stainless stell to match the appliances. All of the metal companies say the appliance manufaturers have a propriety type of lock on the appliance metal finishes. I also have the 532 model.
Good Luck
I have the same problem. How did you get stainless fronts made for it?
