Replaced fuel pump. Now generator will run no more than at idle - starving for fuel. 3kw onan genset
SOURCE: onan 5500
well they have an expensive card in there that controls rpm and voltage to maintain 120v. there is a safety for oil temp in some of those maybe bad try bypassing it after it heats up to pin point it. maybe time to clean brushes?
SOURCE: My lincoln welder/generator with onan engine will
my 20 hp onan won't start it's getting fuel and spark. it will fire and almost run then stop. and a few times poped back through the carb. it has good compresson .and the flywheel key has been replaced
SOURCE: Onan generator: Pro 6000e: engine runs, no
Are you getting any kind of voltage output at all?
