There is an amber light blinking next to the internal jetdirect card. The green light is on as well. The printer will not print. I have done a cold reset as well as changed the ethernet cable. What does the amber light mean?
In most cases an amber lights are usually just connection lights. They let you know the ethernet cable is connected and able to transfer data.
You will want to ensure the printer has a static ip address set in it's configuration, otherwise the ip address will change from time to time causing print issues.
SOURCE: Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
SOURCE: canon i560 won't print
The green light snable, no flashes.But test-print page is empty. All cartridges are full. Print head was reinstalled.
SOURCE: Do I need a new print head?
1. Turn off printer
SOURCE: HP P2015dn printer jam light stays amber.......did
Hello sir;
check very carefully all the senser through the paper path, all the senser have to be moving freely, final go to check the senser board.
Ready light does not turn on and the camera does not work.
Turn on the camera (Turning on the camera).
Install new batteries (Loading the battery) or charge rechargeable batteries.
Turn camera off, then back on.
Ready light blinks green.
Camera is operating normally.
Ready light blinks amber.
Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Transfer pictures to the computer (Transferring pictures with the USB cable), delete pictures from the camera (Deleting pictures/videos), switch image storage locations (), or insert a card with available memory (Using an optional SD/SDHC or MMC card).
Wait. Resume picture taking when the light turns green.
Change the image storage location to internal memory (), or use a different card.
Ready light is off or glows steady green.
