Master
- Posted on Apr 11, 2009
Re: the battery is not charging
Normally, one of 3 causes.
- Dead Battery
- Bad connection of battery interface on Motherboard.
- The AC Adapter sensing pin (In the center of the plug) is damaged (If the system cannot sense the AC adapter, the charging circuit is disabled.)
Troubleshooting:
- Try a different AC adapter (Any Dell D-Series system adapter is interchangable)
- If no difference, then next is replace the battery. (The battery on a portable is a consumable item, and the battery life is generally 300 to 500 recharge/discharge cycles around 18 months)
- If no change with battery or AC adapter, then the failure is the charging circuit of the motherboard.
