SOURCE: newly installed Leviton dimmer switch humming at the switch
You'll need to install an electronic dimmer, like a Maestro. Otherwise, you'll have to live with the hum.
SOURCE: On/off works but dimmers do not. leviton toggle
If each pendant has an individual transformer that is about the size of a hotwheel then you need a dimmer specifically for ELECTRONIC LOW VOLTAGE. A lot of electricians don't know that the different types of lights require different dimmers. Most store bought dimmers are for incandescent lights only, and some nicer dimmers like the Lutron Maestro's are rated for incandescent or MAGNETIC Low Voltage which require a different Sin wave interuption. I don't know that leviton makes a dimmer in that style for Electronic Low Voltage. You could install a Lutron DVELV300P-Wh, but that is a Decora opening. http://www.lutron.com/CMS400/WorkArea/downloadasset.aspx?id=25437
Here is a link to explain the difference in how the dimmer needs to work. Good luck!
Testimonial: "Excellent answer! As Lutron is not available in my small town (on an island in Southeast Alaska) I will likely be ordering a dimmer online. Thanks!"
SOURCE: leviton 057 dimmer 2 black and 1 green wire in a
i want two dimmer switch parrel they both fhave two black and one green how fo you wire it up
SOURCE: I am replacing a Lightolier
It depends. Some dimmers are considered "smart dimmers," where the control on the other end of the 3-way has to be intelligent enough to send a signal back to the dimmer. If the Lightolier dimmer was a smart dimmer, then chances are that the 3-way control was designed to talk only to that specific dimmer. The Leviton product you replaced it with is a simple, basic dimmer - it should work in conjunction with a simple, basic 3-way switch.
If the 3-way control already IS a simple, basic 3-way switch - then I would simply re-check the wiring of the dimmer you replaced.
SOURCE: I remodeled my kitchen and replaced my leviton
Hi Leonard,
I'm a licensed electrician and will be happy to help you get this working again. I suspect an incorrectly wired or incompatible switch or a load that is not designed for dimming. To know which one(s) is the problem and to be able to provide a solution, I need a little more information.
1) What was the old switch brand and model number?
2) What is the new Leviton switch's model number?
3) What type of light bulbs are you trying to operate in the 3 fixtures?
4) What is the number of and wattage of each lamp in the fixtures?
5) How many switches operate the lights?
5a) If more than one switch is used, what is the brand and model number of the other switch(es)?
Thanks
