Kelty Yard King 21" Push Lawn Mower w/ Briggs and Stratton Engine - 96137001200 Logo
A
Anonymous Posted on Oct 08, 2017
Fuel tank Mt fuel tank has split at the top where it bolts on to mower Any ideas how , where, etc i can get this fixed. All the fuel evaporates when I leave it in the shed, and I need to Get this fixed ASAP. It's a yard king petrol mower 21 in blade about 18 years old, I know I Could buy a new one but my dad gave this mower and its still bloody good.
obsteiner
Level 3:
  • Kelty Master 901 Answers
  • Posted on Oct 09, 2017
obsteiner
Kelty Master
Level 3:
Answers
901
Questions
Helped
303235
Points
7223
Try the repair with some JB Weld. It's gas resistant after curing. Just no flame or grinding so the tank doesn't explode.
Weld 8265S Cold Weld Steel Reinforced Epoxy With Hardener 2 Oz eBay
John Kahts
Level 2:
New Friend:
  • Expert 52 Answers
  • Posted on Oct 08, 2017
John Kahts
Expert
Level 2:
New Friend:
Answers
52
Questions
Helped
11974
Points
137
Take it to a traditional plumber, who can work with solder to have it soldered, or anyone who can do soldering.
1 Related Answer
john h
  • 29494 Answers
  • Posted on Apr 08, 2010
SOURCE: need drive belt for old yard king 21" self-propelled mower
most small engine repair or equipment repair shops can cross reference or get a replacement also most online parts stores can get replacement
2013 Harley Davidson FLSTF Fat Boy leaks fuel. But only when the tank is full. Once it gets to a certain point it stops. Any ideas??
Question edited for FULL 'year make model'.
Question moved to the correct category from 'Fat Motorcycles'.
Remove the tanks with fuel pipes. Push a bolt or plug into the open end of the pipes and clamp with a hose clip. Fill the tank and see where the fuel is coming from? The most likely reason is a vibration crack somewhere or a split breather.
Other ideas here
https://www.google.com/search?q=2013+Harley+Davidson+FLSTF+fuel+tank+leaking
P0440 comes up and will not pass . How can I fix this?
Please check one among the following would stop the fuel from passing
  • Missing fuel cap
  • Defective or damaged fuel cap
  • Distorted or damaged Fuel Tank Filler Neck
  • Torn or punctured Evaporative system hose(s)
  • Defective Fuel Tank Sending Unit gasket or seal
  • Split or damaged Carbon Canister
  • Defective Evaporative Vent Valve and/or Evaporative Purge Valve
  • Defective or damaged fuel tank
3helpful
Emissions code is showing code po442. Cannot find any leaks. Already replaced gas cap. What is the other most obvious problem that can be fixed easily?
Common Problems That Trigger the P0442 Code
  • Small tear or puncture in the Evaporative system hose(s) and/or Carbon Canister
  • Small split in a seam of the Carbon Canister
  • Defective or damaged Fuel Tank
  • Defective Fuel Tank Pressure Sensor
  • Defective Leak Detection Pump
  • Slightly loose and/or worn clamps or hardened O-rings anywhere in the EVAP system
Common Misdiagnoses
  • Fuel cap
  • Evaporative Purge Valve
  • Evaporative Vent Valve
1helpful
Can this code p0442 be the gas cap?
Where is the fuel pump located?
The fuel pump is inside the tank and is accessed from the top of the tank, so you'll have to remove the tank.
Disconnect the battery.
Remove the filler cap.
Drain the fuel from the tank(retighten drain plug to 20Nm - 14lbf after draining)
Remove the right hand rear fender liner.
Remove the tank under cover fixing bolts and remove the cover.
Disconnect tank wiring.
Disconnect the piping at the tank(Fuel filler, evap hoses, air breather hose).
The fuel supply and release lines are quick release. Supply has 2 tabs that need to be squeezed before the pipe can be pulled apart. The return line has a square block that needs to be pressed to split the line. The fuel lines may have residual pressure inside so cover with a cloth when releasing so you dont end up with fuel in your eyes. When refitting lightly coat with oil to aid assembly.
You can now undo the tank fixing bolts and remove the tank.(When refitting tighten to 36 Nm - 27lbf)
Once you have the tank on the ground you can remove the pump by undoing the fixing screws and withdrawing it from the tank.
1helpful
The lawnmower starts for a few seconds, then dies.
Probably a fuel delivery issue. There is a brass bolt that holds the bowl to the carburetor on. It has an exterior washer, so don't lose. This bolt also is the main jet for the carburetor and can become clogged especially if old gas is allowed to evaporate in mower and no in-line fuel filter is used. Drain the fuel tank (or it will drain when you remove the bowl!). The bolt has very small holes on bottom and sides. Make sure they are clean and clear and the bolt is nice and cleaned up. Use no metal, and/or scraping on bolt. Reassemble (don't forget the carb body gasket) and engine should run if no other issues.
Please vote on this solution.
Removing tank
Disconnect battery ground cable. Loosen fuel filler cap. Support underneath of the fuel tank protector Disconnect evaporative fuel hose at the canister. Disconnect fuel feed hose and fuel return hose near the fuel filter. Plug both ends of the fuel hoses to prevent fuel leakage. Disconnect air breather hose and fuel filler hose at the fuel filler neck. Cover fuel hose to prevent any dust entering. Remove the four fuel tank assembly fixing bolts at four corners of the tank. Let down the tank and disconnect the wiring connectors Remove fuel tank assembly along with protectors Remove retaining cover and roll over & float valve along with the evaporative fuel hose and pipe Remove fuel pump and sender assembly by removing the snap ring with the fuel hoses Remove protectors by removing the six fixing bolts
Starving for gas
check fuel filter first. rate as fixed if this helps.
Steel Midship, Aerostar
Removal and Installation
  1. NOTE: Make sure fuel tank (9002) is properly supported during removal and installation procedures.
    Drain fuel from fuel tank .
  1. Loosen fuel tank filler pipe clamp.
  1. Remove fuel tank heat shield (9A032) from vehicle.
  1. Support fuel tank .
  1. Remove bolt from rear fuel tank support strap (9092) and remove rear fuel tank support strap .
  1. Remove bolt from front fuel tank support strap and remove front fuel tank support strap .
  1. Partially lower fuel tank to gain access and remove feed and return lines from sender ports. To disconnect push connect fittings, refer to Push Connect Fittings in this section.
  1. Remove electrical connector from sender unit.
  1. Remove fuel vapor hose from evaporative emission valve (9B593) .
  1. Lower fuel tank from vehicle.
5helpful
4answers
Toro TimeCutter z4200 will not start
First check to see if there is a fuel shutoff under the tank. On some models there is a fuel filter screen inside the tank where the fuel line connects to the tank. If niether of these work, R&R the carb.
25helpful
3answers
Fuel pump removal 96 nissan quest
Replace Fuel Pump for 1997 Nissan Quest
(1) If the fuel tank has more than one third full, you need to get the gasoline out. If it has one third or less full, you can leave it in the tank. However be very careful around the working area. Make sure you have read fire precautions in a general repair book. Take the fuel pump fuse out from the fuse box near the battery. Run starter for a few seconds. This will remove the fuel pressure in the gas lines. Disconnect battery at negative terminal. Jack up the rear of the van.
(2) Remove the fuel tank protector.
(3) Disconnect fuel pipes at the front end of the fuel tank. Use short pencils and extra rubber hoses to block disconnected pipes and hoses.
59aa089.jpg There are two pipes connected to the gasoline filler at the side of the van. Disconnect only the smaller one. The larger one is flex enough for the tank to be lowered.
(4) Disconnect the electrical from this connector. Jack the rear end of the fuel tank with a car jack and a piece of 2x4. Put the wood between the jack point and the tank. Then unbolt the two bolts showing in the picture.
(5) Lower the jack after the bolts are removed. The rear end of the tank should be lowered.
(6) Disconnect fuel lines on top of the fuel pump. Reconnect each short hose back to different pipes as shown in picture to block the pipes.
(7) Loose the six mounting bolts on the fuel pump assembly. The bolts should be loosen a little at a time in multiple turns. Also detach the electrical wire holders. After all bolts are removed, carefully take the assembly out of the tank.
(8) Remove the fuel pump from the assembly as shown in picture. Then unplug the electrical wires. Note that two connectors are in different sizes, so that you will not be able to reconnect to a wrong terminal.
(9) Put the new pump and new filter in. Reconnect the electrical wires. If necessary use a pair of pliers to make the connectors tighter. Make sure they are not loose. Reconnect gas inlet to the pressure regulator.
(10) Use a new O ring, put back the assembly to the fuel tank. Make sure the float of the fuel level senser is free, and the assembly is at the right orientation (as shown in picture). Screw back the 6 bolts after making sure the O ring is in right place. The bolts should be tightened in turns. Do not over tighten them. Then reconnect the fuel lines and make sure every fastener is tight. Put the electrical wire into holders.
(11) Jack up the tank and put the two mounting bolt in. (see picture in step 4). Make sure they are tightened with specific torque. Reconnect the electrical connector.
(12) Reconnect two fuel lines at the front side of the tank. Refer to the picture in step 2. Reconnect the hose to the gasoline filler. Before you have a try start, double check if all fuel lines are securely connected and tightened.
(13) Start the engine. You need to crank more than a normal start because the lines were empty. The pressure is built up in some time.
(14) If engine starts ok, turn it off. Then check under the van if there is any leakage. If everything is fine put back the tank protector. (picture in step 2).
Top Kelty Garden Experts
Jay Finke
Jay Finke
john h
Are you a Kelty Garden Expert? Answer questions, earn points and help others
