Question about Raymarine C80 GPS Receiver
Radar screen shows "no scanner". Would like resistance data for cable pin-out from display to scanner head.
Some cable test stuff
Remove the cable from the display, leave the dome connected
I thought the cable end had pin numbers but let me know if it doesn't,
the video pins are 1 and 2 which are located
either side of the key slot
Video pins 1 & 2 resistance 46 Kohms colors 1 white signal, 2
black return
Azimuth 12 &13 resistance 10 Kohms colors 12 purple azimuth +
, 13 grey azimuth -
Trigger 4 & 7 resistance 10 Kohms colors 4 orange trigger
+ ,7 yellow trigger -
Data I/O 6 & 10 resistance 160 Kohms colors 6 green data + , 10
blue data -
Approx. +/- 5 ohms tolerance.
Below is a pin chart of the display connector
key
2 1
5 4 3
8 7 6
11 10 9
13 12
Other pins on display connector
Battery - pins 3 & 5 both black
Battery + pins 9 & 11 both red
Shield pin 8
Dome connections
Video pin 8 white
Video rtn pin 7 black
Trigger + pin 6 orange
Trigger - pin 5 yellow
Data + pin 4 green
Data- pin 3 blue
Azimuth+ pin 2 purple
Azimuth - pin 1 grey
Battery + red
red
Battery - Black
Black
There was a note that some cables only have one set of battery
connections pins 5 & 9
Battery connections on 3 & 11 not present on all cables. You should
have the doubled power wires with the 4KW unit.
If the test results did not have the correct ohms then they said to
check it at the dome
If the dome checked ok, then the cable was bad, and to continuity check
the cable to confirm
a bad cable
Posted on Aug 24, 2008
  • 16 Answers
Hello Clifford,
This is an old message. Are you still having trouble with this or has it been resolved?
Posted on Dec 28, 2007
SOURCE:
Furuno radar 1715
Cek wiring to scanner, change reedswice sensor /heading sensor. If the problem not solve, change the display with the new one.
Oct 01, 2013 | Furuno 1715 LCD Radar System GPS Receiver
NMEA Output from Furuno 6" LCD Radar, Model 1623
No it does not output any type of radar video data.
Apr 27, 2010 | Furuno 1623 Radar 16nm Range
JRC 1000 MKII bearing pulse error on receiver screen. Connections to scanner good and scanner turning. How can I determine if the problem is in the receiver? How can I fix it? louonboard
Normally the bearing pulse comes from the bearing pulse generator built inside the motor. Every time the motor turns it sends a pulse down the line showing the radar that it is indeed spinning. There is also a Heading pulse that comes from an electric eye elsewhere in the housing. The other thing could be that the wire carrying the bearing pulse is not getting back to the display. More so than often, it's the motor. I would have the display sent out to be checked on a simulator if there is a marine electronicshop nearby.
Oct 27, 2009 | JRC 1000 MKII Radar GPS Receiver
No radar target images
Sounds like your video cable inside your radar cable. Also brings your Gain back to zero, STC back to Zero and rain back to zero. Next increase your gain until you see a picture. If none of that is working, check your cable then finally call a dealer.
Oct 15, 2009 | Furuno 1715 Radar 24nm Range
Hi, I have a Radar Screen. Furuno 1942 MK2 . What Radar Dome can i plug this into. I have a Furuno 1720 Dome
A 1942 is a 6 kw radar a 1720 is either a 1.5 or 2.2 kw dome. The two will not work together. Besides the cabling is different. Also the radar cable on a 1942 is round where as the 1720 is square. The 1942 display should work fine on a 1943 navnet radar.
Sep 24, 2009 | Furuno 1942 Mk2 Radar
C120 displays NO DATA SOURCE in the radar section of the screen. ohns resistance test checked out. what else can it be?
1. you must have the latest software 4.29 the new scanner dont work with the old Software.
2. Be shure that you have really put in the connector of the cable inside the plotter its not so easy.
3.
try the plotter on an nother boat with an working system than you will know if its a problem with the antena or Plotter
Aug 06, 2009 | Raymarine C80 GPS Receiver
Furuno 1715 Radar - 'NO HEADING PULSE'
More than likely the belt has come off again. This is a common problem with this radar. You'll need a small allen wrench to tighten it up again.
Jul 02, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Radar Displays the image upside down
If this is on the radar screen, you'll have to set your heading alignment on your radar. The radar may be 180 degrees out. if this occurs on the plotter, then if you have a heading sensor attached or an autopilot, your heading may be off.
Feb 03, 2009 | Furuno NavNet vx2 GP1720C GPS Receiver
1621 radar will not show target
Could be the video wires in the radar cable
Jan 04, 2009 | Boating
Furuno 1622 doesn't work, water coming out cable at screen!
yes the cable should be replaced if you are lucky, the unit is still OK (display) Try the new cable, draped across the boat before rigging. If fault exists with new cable, replace system, or find a new display on ebay
Nov 17, 2008 | Furuno 1715 LCD Radar System GPS Receiver
Raymarine C80 GPS Receiver Logo
624 people viewed this question
Top Raymarine GPS Experts
gerd butler
Level 1 Expert
Goldi Kunal
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
