This is a drive blet problem
To replace the drive belt, you will need to
open the access panel or in some cases tip the washer onto its side to expose the belt on the bottom. Start by removing the back cover, and look for a belt. If you do not see a belt (or a place for a belt - the belt itself may have broken and is hidden from view) and you can see the floor then your washer is a
direct drive model that does not use a belt. If you cannot see the floor because there is a steel floor in the washer, locate the motor and determine if it extends through the bottom plate. If so, then the belt is accessed from beneath the washer.
If you have to tip the washer over, place a large piece of cardboard on the floor to protect the floor and the washer's finish. Because a washer is pretty heavy, you will need an able-bodied assistant to safely tip the washer onto its side. Also, there will be some water remaining in the washer, so have sponges and towels ready to clean up any spill.
To remove the old belt unscrew the clamps securing the pump coupling ( a leathery or rubber flexible part that connects the motor to the water pump). Remove the pump coupling to slip the old belt out. Some models instead require you to loosen the motor mounting bolts and shift it inward to relieve tension on the belt. Remove the old belt.
Place the new belt over the transmission
pulley first then place it over the motor pulley. If it is too tight, place the belt over the motor pulley's nearest edge and then slowly turn the motor pulley to pull the belt around and into the pulley. Replace the pump coupling or tighten the motor mounting bolts. The belt should deflect no more than one half inch when you press on the longest straight run.
Replace the cover and test the washer for proper operation
I have had my washer now for about 5 years and this problem just started last night. I am going to take it apart this weekend and see if I can see anything out of the ordinary.
I did notice that the entire tub seems loose when I move it (I can't recall this being so loose before???).
