I am not sure if it is the heating element or not...
If there's heat inside the drum the heater coils are ok. Check the
exhaust vent, make sure it's not kinked or squished behind the
machine and that the outside vent is not clogged with lint. You should
feel air blowing freely to the outside.
If there is no heat, first
check for 240V at the outlet. If you have 240V, check the
element, the hi-limit thermostat and the thermal cut-off for continuity. If those are ok, it could be a problem with the timer, the
motor or a wiring issue (loose or shorted)
Let me know if you need more assistance.
