You can go to MENU > Setup > Date Stamp to turn it off.
By the way, if you want to edit your photos after taking photos, you can use Leawo PhotoIns. This software is designed as an all-featured photo editor which consists of 2 main modules, including Photo Enhancer and Photo BG Remover.
Photo Enhancer is a professional and AI-powered photo enhancer to improve your photo quality in batch. It can automatically and intelligently analyzes and perfects your photos with AI technology, including face enhancement, color enhancement, lens correction and more.
Photo BG Remover is a professional and one-stop photo background remover to automatically remove background from image. It can intelligently analyze the clipping edges, precisely enclose the region to cut out elements, and magically remove photo background. Besides, it also supports manual adjustment to remove photo background more precisely.
Once you've taken the picture, the date stamp is just more pixels, exactly as if you've taken a picture of a sign with the date on it. Just as a sign hides what's behind it, the date stamp covers whatever was there.
You can use a photo editing program to remove it the same way as removing any unwanted object in the picture. You can crop the picture, or use a cloning tool to try to extend the background to cover the date.
SOURCE: HELP! Getting the date/time stamp off your Vivitar 5100...
When you turn on your camera, press the menu button. That will bring up the screen that has the orange buttons at the top (Capture) (Setup) arrow down using the buttons on the far right side. The down button will be the dame button that you use to delete pictures with. When you get to the botton of the page continue arrowing down and that will bring up another page. Arrow down until you get to the botton there are only 3 items on this page and the bottom item will say the following:
Date imprint ON
Press your enter button (ok button) and up will pop ON or OFF.
Arrown down to the OFF and press enter and that will remove the date imprint from your pictures.
Hope this helps you.
SOURCE: I need the time and date stamp on my pictures-Urgent
The date and time (and a lot more) are stored with every photo in its EXIF metadata. Please consult the documentation for whatever program you're using to print your photos. Depending on the program and printer, you may print the date on the image, in the margins, or on the back.
