SOURCE: Power switch won't work on WF1907 LCD Monitor (Compaq)
Its due to Moisture . Get it serviced and will be fine.
SOURCE: Cannot install: HP Compaq WF1907 Wide LCD Monitor Update.
I found in the folder of Hp the file that does the " UPDATES".
So, thanks for the offer to help me, but all is well now with me and the Hp UPDATES.
Regards
Frank
SOURCE: Compaq WF1907 19" monitor backlights are on, but
Check the monitor on another computer to verify if using correct setting for this monitor will allow a clear image to be displayed.
In windows 7, the monitor should be detected and installed automatically.
What version of windows are you using?
SOURCE: compaq monitor wf1907 is saying
You should check the video cable and also try it with another PC since it is telling you that it is not sensing the video signals from your PC. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
