I am considering installing a Kohler 12RES-L standby generator. There will be a 100 foot run from the planned location of the generator to the transfer switch. What rating and type of electrical cable would you recommend. I expect to bury it in a conduit.
Charles from CT
This is an answer to your question only. The safest thing to do is hire an electrician to do it. There may be factors you don't recgonize that a skilled eye would pick up on.
The proper size wire is #4 copper or #3 Aluminum. THHN is the most common and most versatile type in conduit. a #6 ground wire is ok. Stranded pulls a lot easier than solid and do yourself a favor and buy some wire pulling lubricant just in case.
Make sure to obey all manufacturer's instructions. If you use aluminum make sure to place anti-oxidation compound or Nolox on your lugs in the panel. Please write back with anymore questions.
