Question about Polycom SoundStation 2W (2200-07800-001) Wireless Audio Conference
No Dial Tone
I have no dial tone and you cannot hear on either end. I have unplugged everything and reregistered the unit but it is still not working. I can dial out and it makes a connection but there is no sound or volume on the other end. Hopefully, someone can help me. I have tried everything in the manual. It almost seems like it is in some kkind of mute mode.
  • Anonymous Mar 30, 2009
    I have the same exact problem.
  • Anonymous Apr 17, 2009
    able to make and receive calls, but couldn't hear anything at either end
    if we press any keys at polycom , those sound comes to the other end
SOURCE:
SOURCE: polycom soundstation Ex - no dial tone
Ditto!  must be a common problem.  Anyone have any internal schematic manuals of the guts?  With an internal schematic, I could probably figure it out.
Posted on Jan 06, 2008
JackHeath
  • 1049 Answers
SOURCE: Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
Posted on Oct 01, 2009
male_28_cam
  • 1555 Answers
SOURCE: MY Polycom SE-220 was working fine, then line one
Can you kindly let me know which is the service provider for your line one and what media you are using for bringing the line upto your polycom i.e. copper based wire or some other media.
Posted on Feb 27, 2011
  • 146 Answers
SOURCE: We moved our Polycom Soundstation
sounds like the 'brick' went bad
this is the power supply try replacing it
also and possibly more important did you reprogram phone and phone number when you moved it??
make sure you reset all settings and start new
Posted on Mar 21, 2011
  • 146 Answers
SOURCE: I had two SoundstationEX phones
yes do a full reset and reprogram for new phone number and all settings when you move phones
How do I unblock my phone number
After you enter *67, you hear the dial tone. Dial the outbound number. Your caller ID is not presented on the receiving end.
After you enter *82, you hear the dial tone. Dial the outbound number. Your caller ID is presented on the receiving end.
Sep 25, 2014 | Lands Phones
Everything is working fine on my lexmark all-in-one except for the fax. It is dialing the number and says that it is connecting but will not connect. Have cut it off for a period of time then cut it back...
It could be the fax line in the wall. Try to insert a telephone straight to the wall and listen for a dial tone. If you hear no dial tone, please contact your phone company and have them check the line. If you hear a dial tone, re-plug the printer into the wall using a different known working telephone cable. Try to fax again.
Aug 26, 2011 | Lexmark X4250 All-In-One InkJet Printer
No dial tone pressing hook, NG and Poor line condition transmission report on sending and receiving. Confirmed good dial tone on line in and on phone on ext. Copy, display, everything else fine. I hear...
Make sure that you have your telephone line from the wall jack plugged into the port on the fax that says "LINE" and that your telephone is plugged into EXT.
All your cables and jacks seem like they are working since your phone gets a dial tone, the onyl thing could be that the wires are mixed or the modem on the fax is broken.
Thanks,
Pat
Mar 27, 2010 | Brother Multi-Function Center MFC-240C...
Phone volume
In this case this machine doesnt have an exact way to increase the Dial Tone Volume...... We can try clearing NV RAM on the Printer........ Unplug the Power Supply from the printer....... Press and hold the Stop/Clear button on the Printer and Plug in the Power Supply while holding the Stop/Clear button it should say clearing on the screen at that point u can go ahead and release the Stop/Clear button.......... Now the Printer will ask for the Date Time and Country Language......... Set everything up...... Now hear the Dial tone.......... It should work Fine......... Good Luck...........
Jan 12, 2009 | Lexmark X4270 All-In-One InkJet Printer
Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Jan 07, 2009 | Uniden Cordless Phone
Cordless receivers not working
If you have tried the phone base unit in the same jack that works correctly with your answering machine and you still cannot break dial tone, then you have a defective base unit. Jer
May 09, 2007 | GE 25831GE3 Cordless Phone
No dial tone on handsets
Hey.. Did you check to see if the phone is registered correctly ???
Jan 09, 2007 | Olympia CDP 24201 Cordless Phone
Problem with fax
I'm no expert but, did you try touching the online or hook button on the fax to hear the dial tone? Or connect a basic home phone into the phone jack at the wall the fax was plugged into. Do you get a dial tone. If no dial tone, call the phone company. If there is a dial tone, its the fax.
Nov 27, 2006 | Lexmark F4270 Plain Paper Inkjet Fax
Polycom SoundStation 2W (2200-07800-001) Wireless Audio Conference Logo
205 people viewed this question
Top Polycom Lands Phones Experts
Joseph Wright
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
