No manual - cannot get th cartridges to stop in a place wher I can remove them
Ive just pressed the 'stop' button on mine and it moved the cartridge to show which ink needed replacing and then when pressed again it moved to the replacement gap
hi, nice to meet you all,
i have this day a new problem with printer Epson SX 218 who need to be counter reset, the fact : that the printer is not reconized from her USB port in the computer, seconde, there is 3 green led blinking On bottun, and A4 & 10*15cm/4"*6, so , i tried some flash for ex sx100,sx205 and none of this is working, it show cominucation error E20000......... ,
i call every one, to help me to get manual reset counter from the key board
wait to get help soon , thank you
I have the Epson SX200, I tried to follow diagrams on the printer, which didn't work. I found that if you turn the printer on or off if you look at the white arm which locks the cartridge dock in place,it goes down pull the plug and then you shall be able to move to the gap. Good luck hope it works for you.
Easy solution:
Press The index sheet button and the scan button at the same time.
In the printers window 'set up' will appear. using the left right arrows proceed to 'Ink cartridge replacement'.
Press 'start'. The ink cartridge holder will align itself in the middle of the space where it is easy to remove the cartridges.
I am disgusted with Epson making this so diificult to figure out. Once you know..then you know. but no amount of guesswork would have come up with the solution
I finally managed to figure it out,with the machine on,i kept on pressing the stop button,the mechanism moves slowly to the gap,were i was able to access my cartridges,but you would think epson would supply clear instructions on how to remove ink cartridges.shame on you epson.
Press the menu button on front panel until cartridge change is displayed in the panel then press green colour button and ink carrier will move to centre and ink can be changed
You need the ink cartridge replacement button on Maintenance. But...it doesn't work from the printer monitor. you have to go to the control panel, devices and printer, your printer, customize your printer, advanced, printer default, then maintenance and then the ink cartridge replacement button will work!
Http://www.epson.co.uk/Home-and-Home-Office/Printers-All-in-Ones/Home-printing/Epson-Stylus-SX200/Drivers-Support?target=article&extn=.html&articleId=4437
Gives you a step by step guide to replacing your ink cartridge. Best of luck !
this is not for sx200. i have the same problem and can't get the original ink that came with the printer out to replace it with new ink. how do i get the cartridges to move to the gap where they can be accessed???
we have same problem
