I have a Syncrony Compact that is leaking through the seam in the heater haves. Is there somewhere I can order a new one? Is there some way to repair the present one? I loosened the top and watched while it was brewing (not easy) and could see the water coming through the seam. Thanks John
Usually these cannot be adequately fixed. To get a replacement, depending on where you are, here is the link; http://www.gaggia.com/gaggia_nelmondo.asp If in USA: Importika 596 Fishers Station Dr. 14564, Victor, NY Mr. Salzman Ph. 585.742.5178 Fax 585.924.1499 web site: www.importika.com e-mail: [email protected] Hope this helps :)
Thanks a bunch. I will contact them.
Same problem only place I have found sells the parts is here:
http://www.shop.partsguru.com/product.sc...
i have the same product and it started leaking, was it difficult to fix yourself? I have only had the machine for 11/2 years whats with that!
I have the same problem my gaggia machine just started leaking, they said it is from not being descaled is that true? i have had the machine for 11/2 years, is it easy to fix it yourself with that part.
