Freezer working fine but fridge not getting cold alarm bleeping.Was advised to defrost appliance so, did so.Worked great for a couple of weeks but now back with the problem.Fridge not getting cold just bearly cool with temp light on red continuously !!!!!!
can anyone HELP PLEASE ???????
You have a defrost problem.when you open your freezer door and look at the back panel look and see if their is frost built up.if so that means you do have a defrost problem.you will need to pull panel off and defrost coils.then you can check your defrost thermostat which is round and has 2 wires that go to it.it sits at the top of coils.see if it seperated.if so that is your problem also check defrost heater see if any breaks in it.if those check out then could be defrost timer which is located in ref.side.it would help to know what brand it is.it sounds like a side by side ref,but dont know what brand.
Our fridge/freezer is working fine, but the alarm light on the front keeps on flashing. No alarm sound - just the light. Everything in the freezer is frozen, stuff in fridge are cold - but there is water at the bottom of the fridge. When I turn the temperature ( on the front of freezer - outside ) to any side - the light goes out - but after few hours it is back - flashing... What can be the problem ?
