Rear
Removal
Installation
Rear
Removal
Installation
Item
Part Number
Description
221A00
Door Handle to Door Latch Actuating Cable
Rear Door Control Rod Retainer
Plug Button
Rear Door Latch
5
W623451-S2
Push Nut
6
224A32
Counter Balance
7
22450
Door Outside Handle Tension Spring
8
W701210-S309
Screw
9
224A20
Outside Door Handle Anti Rattle Pivot (2 Req'd)
10
22404
Door Handle
11
224A24
Front Door Outside Handle Spacer (2 Req'd)
12
264A64
Rear Door Actuating Rod
13
22408
Outside Door Handle Anti-Rattle Bumper
14
22428
Outside Door Handle Large Pad
15
N621906-S2
Nut (2 Req'd)
16
N807329
Screw (3 Req'd)
17
26595
Rear Door Electric Latch Actuator (RH)
18
W701566-S47
Rivet
19
431C04-A
Rear Door Latch Striker Assembly
20
Door Lock Striker Plate (Part of Door Shell Assy)
21
W525172-S
Rivet (2 Req'd)
22
264B14
Bellcrank and Link (RH)
23
264A50
Bushing
24
N802034-SG
Rivet
25
26420
Rear Door Latch Control Rod Link
26
W525172-S
Rivet (2 Req'd)
27
21818
RR Door Latch (Inside)
28
A26460
RR Door Latch Push Button Rod
29
21982
Door Latch Rear Striker Assembly
30
N808377-S101
Screw (2 Req'd)
31
250A04
Rear Door Catch
32
N801010-S100
Truss Head Bolt (2 Req'd)
33
N804234-S2
Screw
34
266A74
Rear Door Latch Actuator Retainer
35
24630
Rear Door
36
26552
Rear Door Latch Control Escutcheon
A
Tighten to 21-29 Nm (16-21 Lb-Ft)
B
Tighten to 10-13 Nm (89-115 Lb-In)
C
Tighten to 7-8 Nm (62-70 Lb-In)
D
Tighten to 26-34 Nm (20-25 Lb-Ft)
E
Tighten to 3-4 Nm (27-35 Lb-In)
http://www.howtorepairguide.com/2013/02/honda-pilot-rear-door-lock-wont-open.html
This will help.
Thanks.
You are not alone. I'm also looking for a clue as to what I can do. If I get the solution, I'll be back to reveal it.
You are not alone. I'm also looking for a clue as to what to do. If I come across the solution, I'll be back with it.
Hey maltby, does your outside handle spring back into place after it has been pulled. Mine will not. I've been told that its the linkage on the handle that's broke. Now I need an Idea of how to remove the panel. Did you have to break any part of the panel to get it off? Are you able to see the handle linkage now that the panel has been removed?
