The Champion 2004 has a flush valve inside the tank that I have never seen before. There is a plastic box (with stryrofoam insert) attached to the right side of the flush valve -- and it has broken off. There is no mention what this does in the instruction/parts manual that came with the toilet. Can't find it on the internet.
Does anyone know what it is and if I need to replace it? The toilet seems to be flushing ok.
The foam block does a few things: It helps with noise level, helps prevent condensation and also takes up space in the tank to lessen water usage with each flush.
Keep an eye on the outside of the tank and if you don't ever notice any moisture on the outside of the tank then I wouldn't worry about it all!!
