You may want to check your pump and see if something might be stuck,you should be able to take bottom kick plate off in front of machine.when you take it off you will see the pump.most have a filter you can unscrew and pull out to see how much junk has collected.the buzzing is usually your pump or doorswitch.
listen and see if the buzz comes from the door or from pump.if it comes from the door then door switch may be going bad or is bad.good luck if i can be of further assistance please write back.thanks mike
check pump filter,once the filter is out see if you can put your finger inside pump and try turning the pump blades.
3 screws maybe 2 at bottom of kickplate,sits back a little so they may be hard to see,but they are their,once screws are out you can pull kick plate off.
Thank you I will try that. I shouldn't have said buzz. It is when the washer tries to spin. Sounds like a motor or something
How do I get the bottom kick plate off?
Thank you! It works great now! The filter was really gross! Didn't know it was there and hadn't changed it since we got the thing!
I am still having the burning smell when the washer spins out. Any ideas?
