Scan the document and save it.
Lift the lid on your scanner lay the photo face down then select scan
document/photo it will ask what format you want to scan it then it will ask
where you want to save it browse select the file/folder where you want to save
it (my pictures) most common
you can send an
attachment to a company by an email
Open up your new email type
in the adress then you should see attachment depending on which email you are
using select attachment then you will open up a browse window navigate to
your
document
/ attachment select it you might have to wait a few seconds for it to load as
an attachment then click send.
Formatting the Data Partition
The data partition on the ScreenPlay Director is formatted with an NTFS file system and will appear as a read-only volume under Mac OS X unless special software is installed on the Mac. If you need to transfer files to the ScreenPlay Director by direct USB connection on a Mac, you must reformat the data partition to FAT32 (see instructions below).
NOTE: On a network connection, Mac OS will see the ScreenPlay Director as a shared SMB volume. This means you can use the network to copy files from a Mac to the ScreenPlay Director without changing the format from NTFS to FAT32. (Recommended if available.)
If you reformat the ScreenPlay Director data partition for use with a Windows PC, it is recommended that you use the Windows format utility to reformat with NTFS. Right click on the drive letter for the data partition and select Format.
CAUTION!
Do NOT change the partitioning on the ScreenPlay Director as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition can be viewed or played on a TV.
Formatting the data partition will erase all existing data! If you have files on the ScreenPlay Director you want to save, move them to another drive or volume before reformatting.
