Needed to re-fill gas - but cord locked up on awkward first pull.
Can get out a little - but afraid to break the cord by pulling too hardNeeded to re-fill gas - but cord locked up on awkward first pull.
You can't post conmments that contain an email address.
I'ts a possibility that the engine has seized, remove the spark plug and look at it it will give you and indication if the engine is burned up.I'ts a possibility that the engine has seized, remove the spark plug and look at it it will give you and indication if the engine is burned up.
Having trouble getting pump cover off. Will it come off without removing water/spray gun connections?Having trouble getting pump cover off. Will it come off without removing water/spray gun connections?
sounds like there might be an unexplainable hole in the underside of the engine, possibly from engine being blown up, maybe it has been run low of engine oil?
The pull cord is like a starter on a car (separate
from the motor/engine). If the pull cord will not turn it could be because the
motor/engine is seized.
All internal combustion engines use oil of some description. I take it this is a 2 cycle engine and you have not added oil to the gas. If this is the case the engine is locked up, and must be replaced. Sorry.
The hour meter displays the total operating time. It will flash CHG OIL (Change Oil) at 50 hour intervals. The flash duration is one hour before and one hour after the interval. The CHG OIL icon will come on and shut off automatically. The hour meter can not be manually reset.
first I would put in the proper amount of oil, once you are sure the level is full and if the light still comes on, pull the wire from the oil pressure sending unit, the light should go off with key on, if the light goes off then the sensor is bad. replace sensor
