Will pull the paper so far then stops feeding, even though the printer is still printing. Then once the print is finished the printer responds by the red miss feed light coming on. It looks as if the rollers are not picking the paper up could this be correct and if so is it easy to solve.
Did you check the thickness? My printer won't feed paper that's to think or thick properly it sould say in the manual what thickness of paper you should use.
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takiqq28
i have been using the same thickness of paper for sometime,problem seemed to start after I changed ink.
well i have epson stylus dx4000.
When i try to print it prints but no ink at all is coming out on the paper.
The problem started happening just a few weeks after i changed the ink
Will pull the paper so far then stops feeding, even though the printer is still printing. Then once the print is finished the printer responds by the red miss feed light coming on. It looks as if the rollers are not picking the paper up. How can I maybe change the rollers?
