Hi, I have an Acer Aspire 9300 laptop. The D2D recovery does not work on this laptop, the D2D is enabled in the BIOS! When I press the ALT+F10, it says BOOT MGR is missing. The computer is still loading up with no problems, but I would like to fix this recovery problem. The laptop is running Windows Vista Home Premium.
Hello try this website http://www.thinktechno.com/2008/02/09/how-to-fix-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/ lets try this first and if it don't work we will try something else just copy and paste in your address barr hope this helps bob
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
On startup you will see a message on the acer splash screen to get into "SETUP". This will either be the DEL key or the F2 key.
Go into your BIOS and make sure that D2D recovery is enabled. If you do not see this D2D option then you can exit and should not have to adjust anything else.
when you restart the PC again, hold down the ALT and tap on the F10 key, this will start the recovery partition and load your system to factory default.
This option will only work if you still have your original hard drive in the PC and you have not reformated or reinstalled windows from another media souce.
Contact Acer and have them send you a new recovery disk. Be sure to have your computers paperwork handy when you talk to them. The problem" operating system could not be found" could be software or hardware related. I'd try to load the OS using the recovery disk first and see if that fixes the problem... mpawlak
Enable disk-to-disk recovery
On boot, press <F2> to enter BIOS. To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility, then select Main from the categories listed at the top of the screen. Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled. Save and reboot. While the Acer logo is showing, press <Alt> + <F10> at the same time to enter the recovery process. Refer to the onscreen instructions to perform system recovery.
Hi there You want to restore your computer to its original settings without recovery CDs? This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option. Before performing a restore operation, please check the BIOS settings. 1 To activate the BIOS utility, press <F2> during boot up. 2 Check to see if Acer disk-to-disk recovery is enabled or not. 3 Make sure the D2D Recovery setting in Main is Enabled. 4 Exit the BIOS utility and save changes. The system will reboot. To start the recovery process: 1 Restart the system. 2 While the Acer logo is showing, press <Alt> + <F10> at the same time to enter the recovery process. 3 Refer to the onscreen instructions to perform system recovery.
When you first turned on your laptop from new, you should have been prompted to create back up disks of your system.
If you did not do this, then you can try the following.
Most models of Acer Aspire have recovery system capabilities.
When booting up press F2 to enter the bios. Make sure that D2D recovery system is enabled then exit and save the changes. Press Alt+F10 to enter recovery. If this does not work for you then contact Acer for replacement recovery disks.
Is the d2d erecovery function enabled in the bios?
To check, activate the BIOS utility, press <F2> during the POST; while the notebook PC logo is being displayed.
To enable D2D recovery ard disk recovery), select Main from the categories listed at the top of the screen.
That should allow you to use the F10 function key to activate D2D.
* Note: D2D e-recovery is not in Acer Empowering Management.
AEM is a power management utility that supports ACPI (advanced configuration and power interface) which allows for maximum power conservation and maximum performance. (Managed by the windows OS)
