How can I fix our Tappan stove glass top?
Glass tops are generally not too hard to replace but they are expensive. It is usually a lift off top with a few wire harnesses. Visit my website www.60cubits com. Check the link for "repair clinic". Put in your model number and find your replacement. If you have trouble, leave me a message there and I will try to walk you through it.
SOURCE: Replacement of glass top
Unplug first! Find the screws that hold the cooktop to the range. Usually in the front just above the oven door when it is closed on the underside. This should release the cooktop. The burners and wiring may have to be removed. You can order the part at sears.com.
SOURCE: broken glass cook top
The top can not be repaired. The glass must be replaced . DO NOT USE IT CRACKED!!!!!!!!!!!! This is very dangerous as it can explode from the temperature. Also this is a severe electrical danger as glass top units have exposed elements underneath. Any liquid at all can short it out and cause a fire. I don't know if it is worth repairing. I don't have the exact price for your cooktop but last one I priced was between $350 - $500.
SOURCE: JENN AIR GLASS TOP REPLACEMENT
the glass top replacemnt is a pretty straightfoward task, a matter of unscrewing one and repalcing it wiht anew one. after ordering new top its a matter of lookin g at eh new top to see which screws would need to be removed from old. hardest part about job will be youll need to do disconnect the downdraft from the venting ,and pull unit up from the counter inwhich it is installe.< not difficult but cumbersome and awkward to manuver. check abd verify full model and serail number and cal manufacture for correct part umber. may cast anywhere fom 200-400 dollars depending on model
SOURCE: Siemens glass stove top - locked mode
you have to hold the powerbutton for a few seconds, and the children security lock should come off
SOURCE: Burned Copper Bottom Pot on Glass Stove Top
sorry to say no , if you try to peal it off or scrape ot off you will crack the cooktop . this keeps happening i have seen it at around 4 times for some reason revere ware melts . there should be a warning in the manual ( i know ge does have the warning about copper bottoms ) . replaceing the cooktop or the whole stove is the only "true" answer .... sorry .....Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
