Question edited for clarity, make and model what it is.
Question moved from Laundry Dryers to one of the Braun categories.
My first idea was to throw it out and buy a new one until I saw it. This is a substantial piece of appliance. Somewhere you have water mixing with electricity. The most likely part is the heating element or the connection to it. It also have a very substantial circuit board and it has a pump. If the tube to the pump has a leak it may be spraying onto the electrics. There is a pretty good disassembly video here.
I have the same issue, still looking for the root cause. So far i've fixed the microswitch, the valve and the electronics main board, the issue remains, so it's not coming from that.
I finally found what the issue was in my case. The problem was with the led indicator light on the iron (the one on the front, close to the buttons on the iron itself). This was shorted and was causing the electronics to latch the EV continuously when powered. I just removed the led and it's working fine. You just need to remove the white cable to the led on the screwed connector on the back of the iron, if you don't want to mess with disassembly the whole iron.
A steam iron generally produces steam in use as the movement allows water in the reservoir to move around and small amounts will escape into the heated sole plate.
The button to produce extra steam is mostly a small pump similar to those found in trigger sprays and hand soap bottle pumps and this is connected to the sole plate by a small-bore hose. It is far from unknown for one or more of the little hose(s) to become disconnected, often because of a limescale build up - even though the modern steam iron is advertised as needing only tap water, this is suitable only in soft water areas. Irons used in hard water areas tend to have a much shorter life so an alternative is advised.
My description doesn't apply to every steam iron - in some older designs the extra steam button opened a valve in the bottom of the reservoir to allow water to gravity feed into the sole plate. Although almost exclusively found on irons from the premium end of the market they were a nightmare of rods and rubber seals no longer lasting or reliable than those with a cheap plastic pump.
Clearly your iron needs dismantling and repairing if you can do this yourself, or replacing if you can't due to the disproportionately high repair shop cost. Some years ago my wife gave up on premium irons and began to buy the cheapest and was at first happy to replace them fairly often saying she found them no better or worse than the expensive ones. The first couple only lasted a couple of years each but the last one is now six or seven years old and still going strong.
There are no user serviceable parts but if you grandma's diamond is inside, try to find snap-together locations between plastic parts and remove any screws you can at the back end. Most irons have screws only at the stand/rear end and can then access cord connections, etc. Once you get started it will be easier to see what the next step is.
You need to follow the instructions for the iron. Rowenta make a excellent iron but it's water tank and steam chamber need to be cleaned and rinsed out, say every third use depending on how much you use it. Also, allow the iron to reach FULL TEMPRATURE before you use it.
Scale buildup is unseating the rubber seal. Disassemble the iron. (Water filler hole part pulls directly forwards and can be pushed out from behind with a screwdriver.) Otherwise it's fairly straightforward. Clean scale off baseplate. Seal with silcone gasket before reassembly.
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
