Home Logo
Anonymous Posted on Mar 24, 2009
Water marking/etching glass sink
This is the second time I've had a problem with water standing in the bottom of a glass vessel sink. Maybe poor design, but I can't change the shape now! Unless the water is sopped out with a cloth, it sits in the bottom and although it is a small amount, it's producing an etch type ring. I've had no luck with any products to remove this. I was sopping it out, though while I was away for a week, a house guest didn't know of the problem. It's like the ring you can get in a glass vase. Anybody have a 'solution'?
Thanx, Mia
  • Anonymous Mar 28, 2009
    Hi Gregg,
    Thanks for your solution. I tried the half and half, then went to full strength. After sitting for 1/2 hour, it improved a lot! I will let it sit longer, though I'm hoping the full strength won't hurt the rubber seal on the pop up drain.
    Thanx a bunch
Gregg Rene
Level 2:
Sniper:
  • Expert 86 Answers
  • Posted on Mar 27, 2009
Gregg Rene
Expert
Level 2:
Sniper:
Answers
86
Questions
0
Helped
92458
Points
316
Hi Mia,
Glass sinks are beautiful! The water deposits you speak of can be from two sources - hard water in which mineralization occurs, and alkaline products or alkaline water. If you have mineral deposits they will easily remove with vinegar and water solution, start at a half and half mix.
It is recommended by most manufacturers to wipe the water out after every use, which is not usually told us when we make the purchase, is it?! :-)
If this is a vanity or bathroom sink, you want to be especially careful that you do not pour or spill cosmetics, skin care products, nor other subtsances that may be alkaline. Many facial cleaners, toiletries, perfumes and household cleaners are alkaline. If you have alkaline damage, it's not possible to repair the etching.
I will hope your problem is hard water or water deposits - try the vinegar solution. I use white vinegar. Good luck, and we'd love to see a photo posted of your sink!
Gregg
  • Gregg Rene Mar 28, 2009
    I'm glad it's working for you Mia! The drain seal should be rubber or a plastic, both are very impervious to the vinegar, which is a very diluted (one percent or less) acetic acid, so I would not worry about this.
    If you find the normal cleaning of the deposits becoming too much work or too frequent, then you might consider installing an under-sink water filter or softener. While the replacement filters are not always inexpexensive (be sure to research replacement filter costs when considering purchasing a filter), it will eliminate the problem - plus the water drinking quality will be much improved!
    Thank you for using FixYa.
    Gregg
Anonymous
Level 2:
Sergeant:
  • Expert 149 Answers
  • Posted on Mar 30, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
149
Questions
Helped
74117
Points
558
Mia try some tsp or tri sodium phosphate available at local hardware store. good luck dont forget to rate
My tempered glass vessel sink exploded. Does this happen often?
No it doesn't and it is not supposed to. They didn't have the temper right and it should not have happened. The manufacturer will tell you that you must have chipped it or hit with something and the water temp made it burst. Don't buy it, Glass is tough, and when done right, does not explode easily. Hope this helps.
White film over glasses . still water in bottom, not cleanign dishes.
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Installing a vessel sink
Standard Vanity height is approx 34.5". A vessel vanity is approx 31" high. If you cannot remove the legs from your existing vanity then it will have to be replaced or cut down to the correct height. The reason a vessel vanity is lower is because your sink will be approx 3 to 6 inches higher than a standard drop in sink. This may be more work than it is worth. Vessel sinks most often will require a solid surface top, either glass, stone or another type of composite material. The standard laminate vanity top has a particle board substrate which will detiorate quickly at the drain location.
2helpful
2answers
Some water sits in the bottom and does not drain completely. Don't know if the drain inside the sink was not properly installed or if the sink is designed that way.
this is not supposed to happen, either drain not installed properly or drain is clogged. suggest trying drain cleaner first if sink has been in for a period of time. if sink is recently installed call whoever installed and have them fix the drain
2helpful
2answers
New Vessel sink is leaking at the spud gasket.
well if he is afraid then you take a chanel lock plier and go under the sink and titen it
The sink leaks at the bottom of glass sink where it connects to the piping
THE PART YOU ARE TALKING ABOUT IS CALLED DRAIN TAIL PIECE. THE DRAIN YOU CAN REMOVE BY LOSENING THE NUT UNDER THE SINK WHILE SOME ONE HOLDS THE DRAIN INSIDE THE SINK FROM TURNING THE OART KEAKING IS CALLED A SPUD GASKET WHICH SEALS THE DRAIN TO THE SINK
2helpful
Vessel sink drain causes poolin of water.
YOU ALSO HAVE A VENT ISSUE, THE VESSEL SINK DOESN'T HAVE THE LITTLE HOLE IN IT LIKE A VANITY SINK, THERE FOR THE WATER IS GOING DOWN THE DRAIN BUT THE AIR CAN NOT COME OUT, YOU NEED TO INSTALL A STUDOR VENT OR AN INLINE VENT INTO THE DRAIN BETWEEN THE WALL AND THE TRAP CUT IN A TEE AND BRING A PIPE UP TO THE BOTTOM OF THE COUNTER TOP AND INSTALL THE VENT, USALLY HAVE TO PUT A FEMALE ADPT ON THE TOP OF THE PIPE THE VENT COMES WITH THREADS DO NOT GLUE IT IN PLACE, THEY HAVE A RUBBER FLAPPER THAT OPENS WHEN THE WATER IS GOING THRU THE DRAIN AND ALLOWS IT TO PULL IN AIR THEN THE FLAP CLOSES WHEN NO WATER IS RUNNING TO KEEP THE SEWER SMELL OUT
2helpful
Poor Draining of Vessel Sink
have the plumber pop an opening on the side of the drain pipe under the sink. and add a indoor vent.
Etching on Pegasus sinks from standing water on clear sink
You can get an acrylic sealant to put around the drain. It will fill the void where the flange on the drain hole and the sink meet. Possibly an epoxy would work but some tend to yellow with age.
Mar 16, 2009 • Home
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
