String problem
Donna, take the spool that holds the string off. Look to see which wat the string is supposed to be wound onto the spool. If the string in on correctly, check to see if one or more of the turns of the string is overlaying itself. If there is overlap, clear it out by unwinding enough to unlap it. If the string is going the wrong way when you check it, remove and save the string from the spool, rewind it in the correct direction, put it back onto the machine and see if that corrects the problem. Woman or not, you are smart enough to ask, you are smart enough...Good luck...Lee
