When it go from an application to the home screen mean it crash the Application. This may be the cause of : "iPhone is out of memory (RAM), or the application itself have bug ) it's not actually because you install too much application. But if you reduce the number of application your iPhone sure will run faster. From now on if you play a game or open a application that usually crash try to restart your iPhone ( hold down both power and home button until you see a black screen with the Apple logo) . You'll see that game or application will run faster and crash less maybe not at all. Good luck and hope this help.
My friend had the same problem all he did was delete the aps and redownload them through itunes and they worked fine after that
hope this helps
My phone isn't very well, so I want to find an app to clear junk and cache, now I found it! That's LEO Privacy, it uses a little storage, and with it, I also make my phone light. This is a wonderful app! This is also the best app that I used on my phone.
https://goo.gl/rl0dX8
Leo privacy is small in mobile phone,locks apps and boosts the phone and have many other features,the best application I ever downloaded and also good for low ramed phones.Very efficient, really keeps snoopers out...
If you go over the 4-5 pages worth of apps then your iPhone will tend to crash often as the free RAM is being used and there is none available.
Try turning your iPhone off after installing an app.
Else just remove the ones you don't use.
:D
The phone is starting to crash a fresh restore should do the trick
Probably what it is one of the apps is corrupt and they all need to be removed from the phone, and synced with itunes to put them all back on
That is because applications like safari,mail are always running in the background and when you open more apps the system memory gets low so the iphone quits the app.. Download memtool from cydia. It will help you to close apps running in the background
Sometimes the iphone crashed returning to the home screen much like a computer, maybe delete some applications.
Thats shouldnt matter how much apps you put on ur iphone. this sometimes happeneds when you reactly updated your iphone and you downloaded the apps b4 the upgrade you should try to restore it and this should downgrade your firmware back to normal and everything should be fine if that doesnt work delet the app and download it again hope this helps
The reason why it does that is not because of ur applications and games on the phone, its because after every download or multi downloads of games and apps, u must turn off the iphone and restart it. the iphone also requires the phone is be turned off every day or every other day. the reason for this is because the iphone must be reset other wise its like a normal computer with many many programs open, it chokes. the only way to clear up this used up memory is to turn it off and back on.
a second way that sometimes helps out in different ways is, push the top button and the main home screen button at the same time for 8 seconds.
It may just be that the application in question crashed. You want to remove apps that you don't like or dont use. Keep track of what crashes and when.
Try rebooting the phone (turn off and back on) if this keeps happening.
SOURCE: GPS not working
Try this -
1) Settings > Enable 3G Change to Off.
2) Use the iPhone GPS receiver to locate your position
3) Settings > Enable 3G change to On.
There are two positioning systems in the iPhone 3G, one is the 3G network, and the second is the GPS receiver. The problem occurs when the data from the two systems doesn't match.
SOURCE: iPhone 3G repair
look here, do you want to find a professional supplier for your iPod and iPhone parts,pls contact Luna Commerce Limited,we asure you good quality parts and offer long period warranty,more details pls access our website or email to me,thank you. [email protected] www.lunacommerce.com
SOURCE: The Home screen on my iPhone 3G is huge, and I'm
Try tapping the screen with three fingers at once.
Testimonial: "Perfect, this did the trick, thx!"
Reset the phone:
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
its not your phone... its the applications that crash because they havent been debugged... generally turning the phone off n back on solves the problem...
