My Landice Sprint 8700 powers on and stays on. The elevation buttons work and the treadmill moves up and down. When I press the speed buttons, the screem shows the numbers going up and down; however, the belt does not move. When I initially turn the maching on, the wheel part of the motor gives a slight jerk. The motor is a Baldor, serial number 7-43974. Any idea what might be wrong and how much it would cost to fix. I plan to sell the treadmill after it is fixed. Thank you.
See the video and procedd according. However you must LUBE the deck belt very well+rollers bearing front and back+test the drive belt motor, and replace if necessary. God bless you
SOURCE: Describe your Spirit ® XT275 Folding
Hi
Thanks for using FixYa. Please read this out:
How to Troubleshoot a Treadmill
If still the issue is not resolved then you can contact local repair center.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
SOURCE: my sportsart 6150 treadmill gives an error code 1
I would say that it could possibly be a speed densor fault as error one means loss of speed signal!! If the mat moves first then error one shows i would change sensor before changing anything else, if the mat does not move it could be a lower control board fault.
SOURCE: Proform 590 HR Treadmill. Belt won't run
Hi, i fixed one just the other day, the control unit fails.
broddersbaldrick on a big auction site fixes them :)
Hope this helps
SOURCE: F85's "low speed" error
Dear Sir:
1) Lube the deck belt very well, as your instruction manual indicate for maintenance.
2) Try to Run software calibration after you fix it. For easy diagnose and troubleshooting.
3) The elevation motor can be faulty for lack of maintenance too, again Run the software calibration.
sincerely. God bless you
SOURCE: landice L7 treadmill won't turn on
1)LUBE the deck belt, maybe you have a deck belt worn, by lack maintenance.
2) Lube the rollers bearings, in according with the maintenance schedule.
3) Test the main motor for voltage input, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
5) After fixing RUN the software calibration for diagnose, and troubleshooting.
ERROR
CODE # 7
E7-
1) Alternative Elevation Motor
1)Cause:
Elevation Motor not moving Solution:Check
Elevation Motor connection
2)Cause:
Elevation Elevation Motor screw binding Solution:
Clean screw and lubricate
3)Cause:
Elevation Motor Motor out of Range Solution:
Check motor out of elevation
4)Cause:
E-Motor Potentiometer: Solution:
Replace Elevation Motor
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
On/Off switch Solution:
Test unit is turned on b)Cause:
Insufficient Power Source Solution:
Plug
dedicated120V, 20Amp Outlet
c)
Cause:
Line
Cord Damaged Solution:
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
